Callout icon and color doesn't change for a custom callout with metadata
Following custom callout works perfectly fine
	.callout[data-callout="test"] {
    --callout-color: 0, 0, 0;
    --callout-icon: lucide-lightbulb;
However, after adding metadata to the title, which I need for a gallery, both icon and color revert to default:
	.callout[data-callout="test|gallery"] {
It looks like a bug, however on the Bug reports page it’s said that issues with css can’t be a but.
The CSS for alt/attribute text is data-callout-metadata="". e.g.
.callout[data-callout-metadata="gallery"] {
Then you can use |gallery] on any callout type to set that style.
Thank you, I understand that, but it’s not the problem I’m trying to solve - I’m frequently using image gallery custom css snippet which uses custom metadata gallery to make series of image a gallery:
And I want to have pre-made gallery callout, with the metadata already specified.
It works, but the color and icon of the callout are reverted to default with any specified metadata:
What was I trying to indicate in my previous post is that I’m fairly certain .callout[data-callout="test|gallery"] is not going to work. The attribute/alt/metadata section needs to be written differently.
In any event, with the MCL gallery snippet enabled and adding this in my own snippet file:
.callout[data-callout-metadata*="gallery"] {
this is what I’m seeing on my end:
Be sure to reload Obsidian or close-open the note when making callout icon changes. They don’t show immediately when saving the .css file like changing the color does.
Thank you so much, indeed works. So it’s styling callout based on metadata, not on name, haven’t realized that the first time.
Yup. You can do either.
Glad it worked out. :christmas_tree:
