Callout doesn´t render colors darker/lighter than theme background
So it’s a very minor issue but I want the body of callouts to be darker than the base color used as the background on the note. It works fine in source/edit mode, but on reading mode I just can’t get it to work. The same happens with photos too.
I tried applying the snippet on multiple themes and on multiple devices. I even tried using another snippet to override the bg color of the note, but no change. I looked through the forum and didn’t find any topic about this either. Here’s the code i’m using
.theme-dark .callout > .callout-content {
  background-color: #000000 !important;
here’s the result on the prism theme, edit mode vs. reading mode
It works fine with any color lighter than the base color, but not darker colors. I wanted to know if there’s something wrong with my code or just an issue of the program itself. thanks!
Hi @nightriderlily,
Prism has a specific way of customising callouts outlined in the wiki here:
As for your specific use case, the following snippet should do what you want in Prism:
.theme-dark.prism-theme:not(.pt-disable-callout-styling) .callout > .callout-content {
    background-color: #000000;
hi, thanks for the reply. unfortunately it doesn’t seem to work either :confused: it’s the same as the previous code, works only with lighter colors than the background. i also tried it adding “!important” but nothing. here’s what i mean
screenrecord
Try changing the --callout-blend-mode variable. Maybe something like:
body {
--callout-blend-mode: normal !important;
or
body {
--callout-blend-mode: darken !important;
this solved it, thank you so much !!
