Calibre plugin “highlights to obsidian” difficulty
Hello everyone! I encountered the following problem when using the title plugin “Highlights to Obsidian”:
Calibre reported an error “Vault not found”, where the plugin configuration of Calibre and the library name of Obsidian are the same, both are “note”
The following is a screenshot of the error:
error
The versions of Calibre and Obsidian are both the latest versions.
Could you please give me some solutions? Thank you!
Solved, thank you everyone
After trying all of the methods and apps and plugins this one is what I use for kindle highlights.
Remarkable.
