I’ve installed the Reminder plugin on both Windows and Android.
On Windows the Reminder plugin works fine with task the pop up calendar comes up and I can select the dat I want.
go to shop (@18-07-2024)
Woopee doo great.
On Android there is no calendar popup appearing.
Why is this?
I know there is this:
- Notification in mobile (Android/iOS)
- System notification in mobile device is not available because Obsidian doesn’t provide the feature.
That’s ok but it still doesn’t tell me why there is no popup calendar at all.
I’ve checked the settings on both Android and windows plugin and both are the same.
Not sure if I’ve left off a setting or it just doesn’t work properly in Android.
