Calendar not showing up in right pane
Installing, uninstalling, activating, deactivating, asking on discord, searching the docs on github, and posting an issue on github.
Just get the simple calendar plugin to display in the right hand pane. I’d settle for anywhere at this point.
I’m using Windows 10, Obs 1.0.3, default theme.
OK, just got it showing. Scrolled through ALL of the issues on plugin github, and someone said to click in the right pane, which makes the calendar icon show up above the pane. Then clicked on icon and boom. PEBCAK…
