#some code
- A bullet point that I want indented by one level
I expect to see the code syntax highlighting end completely after the second ```
On indenting a bullet point (-) one or more levels, the bullet point is captured by the syntax highlighting of the code fence.
  • Operating system: Linux Mint
  • Obsidian version: v0.6.5
  • Using custom CSS: No
This happens with ANY text indented with a blank line above it.
If you type any character on the blank line (except space) the text below returns to normal.
Obsidian_20-06-08-37_248x180
Obsidian_20-06-08-38_389x239
This is not a bug. It’s the markdown syntax.
Black line above + Indented text = code block
https://www.markdownguide.org/basic-syntax/#code-blocks
Hi, I came across this today with the same issue.
With the understanding that I can’t just ignore parts of markdown I don’t like, I wish I could ignore this part. I use lists with line breaks in them all the time, and an indent seems like a very frequently used character to start something as infrequently used a code block, which has an entirely separate syntax for it. I’ll take it up with Gruber I guess.
In the meantime, are there any workarounds for this? The hacky way I thought of is to just change the CSS to prevent rendering code blocks entirely. It would be nice if there was an option in the future to render anything within a collapsable indented list as part of that list though.
Thanks!
