Built a plugin to integrate Web Components into markdown preview
I have built a plugin to load Web Components as ‘Widgets’ into the Markdown Preview. The components are also provided with an interface to create new notes and query notes with a specific types. For them each note represents an entity or object. As you can see the styling is still a bit rough.
Right now I am building myself a collection of Custom Components for my personal usage, including a Task Board, a Calendar and Planner, among different other ‘widgets’.
The base plugin is ready to be released and I will do so in the coming weeks. It is a simple Markdown postprocessor that loads JavaScript from a custom location and appends it to the window.
The hard part was to build the infrastructure that allowed components inside the preview to interact with notes. There are still a lot of limitations like how files are cached and refreshed in Obsidian, but in general I have successfully built the following modules:
  • an indexer that indexes files by their type frontmatter property
  • a write interface to create entities as files inside a defined location and notify widgets about new entities in real-time
Who do you think could benefit from interactive widgets in their notes?
Some additional context:
The original goal was to build a plugin for a more advanced calendar, and since I am a web dev I wanted to build a solid foundation from where I can just add features by writing svelte components (compiled to web components).
Should I continue building the app for users or should I focus on providing the building blocks to the community so other devs can build on top of it?
I don’t have a usecase but the concept is interesting. I’m excited for the release.
I’m not familiar with how obsidian plugins work, will I be able to see the code once you release it?
You would be if I released it in its current state, but I since decided to pivot the project and scrap the file indexer for an integration with Dataview and the existing Kanban and Task plugins. They already did a lot of the heavy lifting, especially when it comes to dealing with the file caching, which is a complete nightmare imho.
I learned a lot by indexing files myself but the best code is the one you never write.
