[Bug] Toggle Heading toolbar button doesn‘t work anymore
Here is a screen recording
Screen recordings.zip (3.7 MB)
It could be caused by Android. But it worked first with Android 12, then after some obsidian update in early 2022 it stopped working. Since then it did not work with Android 12 and 13.
It is probably a problem with the popup menu at the h-button
Hello,
in my case there is probably another related error.
I use as keyboard Gboard. Sometimes the bottom button bar is pushed up with, so that it is usable above Gboard, but often it remains invisible behind the Gboard keyboard. The error occurs with all keyboards I use (Gboard, Samsung-, Hackers-, VH-, Keypass keyboard).
will be fixed in 1.4.2
The problem with the heading is fixed in the new version.
The second problem that the bottom button bar is invisible behind the gboard keyboard isnt fixed. Most time it is invisible and sometimes it is usable above the keyboard
Report this in a new thread (or add to a thread that already exists). It won’t be tracked here.
