This is related to third-party plugins, but it happens with at least two different plugins by different authors, and the plugins are from top-10 most popular ones, so some main app error might be at play.
  1. Enable the Calendar plugin or Advanced Tables plugin. For the Advanced Tables plugin: enable the pane by tapping the newly added plugin icon in the left navigational strip.
  2. See that the item is present in the right pane.
  3. Reload the app.
  4. Disable the plugin
  5. Note that the item is still present in the right pane (shouldn’t be already).
  6. Reload the app.
  7. Note the items in the right pane.
An item created by a plugin should disappear from the pane after the plugin is disabled.
Empty item is present in the pane, survives app reload, until removed by hand by opening it and tapping the cross to the left of “No file is open” heading.
  • Operating system: Android
  • Obsidian version: 1.0.4
The screen recording of the issue:
