[BUG] Obsidian Git complaining about `index.lock` even when file index.lock doesn’t exist
I get the following output when I try to commit my changes to my obsidian git repo, For reference, I get the below output in DevTools
plugin:obsidian-git:411 obsidian-git: Error:
致命错误:无法创建 '/run/media/wangx/STORE N GO/SNotes/.git/index.lock':文件已存在。
似乎另外一个 git 进程在这个仓库中运行,例如:'git commit' 命令打
开了一个编辑器。请确认所有进程都已经关闭然后重试。如果仍然报错,
可能之前有一个 git 进程在这个仓库中异常退出:
手动删除这个文件再继续。
    at Object.action (plugin:obsidian-git:150:11265)
    at Fq.exec (plugin:obsidian-git:150:11761)
    at eval (plugin:obsidian-git:149:6943)
    at new Promise (<anonymous>)
    at ww.handleTaskData (plugin:obsidian-git:149:6832)
    at ww.attemptRemoteTask (plugin:obsidian-git:149:6488)
    at async ww.attemptTask (plugin:obsidian-git:149:5970)
displayError @ plugin:obsidian-git:411
commit @ plugin:obsidian-git:400
await in commit
eval @ plugin:obsidian-git:395
handleTask @ plugin:obsidian-git:103
addTask @ plugin:obsidian-git:103
s9 @ plugin:obsidian-git:395
El @ plugin:obsidian-git:391
Translation: (Couldn’t create file index.lock, it already exists.) Seems another git process is running; ensure all processes are closed then retry. If not, then try deleting the index.lock file manually.
[wangx@wangx-acer SNotes]$ ls -laR | grep lock
[wangx@wangx-acer SNotes]$ ps aux | grep git
wangx   11440  0.0  0.0   9732  6348 pts/0    S+   13:02   0:00 grep --color=auto git
When I checked, there seems to be no index.lock file, or any file named “lock” at all. May I please know what this issue entails and if there is any possible solution?
For context, Git in the Terminal works fine, and I’m on EndeavourOS Linux.
Thanks.
For additional context, Obsidian Git works fine on Windows.
Just not on Linux.
Update: Obsidian Git works on a Btrfs partition on my removable flashdrive on Linux; it failed on the original FAT32. On Windows it works with FAT32.
