Platform
[ ] iOS
[x] Android
Obsidian Mobile version: v1.05
Steps
  1. Open a file/pane
  2. Try to close a file/pane
Expected result: either an “x” (preferred) or a menu “:” option or buttons, something to close the pane
Actual result: nothing obvious
I know someone will try to correct me that it’s a feature request but it’s a basic function to be able to close something in a UI. On the desktop app there’s a simple and clear “x” but on Android it took me forever to figure out how to close the panes. Hint: Use commands > search for close > there you go
Like you I just learned on Discord that you have to long press the three-dots to open the close menu :upside_down_face:
