Bug: Input method switcher popup disappears when long-pressing the globe key in Obsidian (language switch)
When using Fcitx5 Android in the Obsidian Android app, long-pressing the globe key (:globe_with_meridians:) to open the input method/language switcher causes the popup to disappear immediately.
  1. Open Obsidian on Android.
  2. Open a note and tap the text editor to bring up the keyboard.
  3. Long-press the globe key (:globe_with_meridians:) on the keyboard.
  4. The input method/language switcher popup appears briefly.
  5. The popup immediately disappears by itself.
The input method/language switcher popup should remain visible after long-pressing the globe key, allowing the user to select another input method or language.
The popup appears but immediately disappears, making it impossible to select an item from the popup.
App: Obsidian for Android
Input method: Gboard Android
Platform: Android
Affected input field: Obsidian Markdown text editor
Thanks
  1. Open any note or text field (even the search box) on Android and use Google’s G Board as your keyboard. You must already have multiple keyboard layouts / language input schemes installed within G Board.
  2. Long press the space bar or language switcher key, which should open a modal for selecting a keyboard/ language from a list of those that have been installed.
Did you read and follow the Troubleshooting Guide ? [Yes/No]
Yes. The bug still appears in restricted mode. I even tried with and without Vim keys. The bug does not appear in any other text input field in any other app.
A modal should appear, allowing for the selection of a different keyboard / language.
With this bug the modal either fails to appear at all or closes immediately after opening.
Obsidian version: 1.14.4 (389)
API version: 1.14.4
Operating system: Android 16 (samsung SM-S9280)
Webview version: 154.0.8037.57
Catalyst license: none
Live preview: off
Snippets enabled: 1
Plugins installed: 25
Plugins enabled: 15
1: Advanced URI v2.2.0
2: Markdown Furigana v1.3.0
3: Smart Random Note v0.2.1
4: Sort and Permute lines v0.9.0
5: Vimrc Support v0.10.2
6: Dataview v0.5.68
7: Icon Shortcodes v0.9.7
8: Tasks v8.4.0
9: Style Settings v1.0.9
10: Linter v1.33.0
11: Templater v2.25.1
12: Create Note in Folder v1.13.0
13: VirtFolder v1.1.28
14: Media DB v0.9.1
15: Link Exploder v0.3.0
https://photos.app.goo.gl/iYtEXVaoAGM7H3McA
Using a Moto G32 with Android 13, also having this issue. Same version of obsidian, no plugins at all, pretty much default. However, this isn’t just an obsidian issue. Also affects any chromium browser, specifically webpages as the address bar, find in page bar, etc are completely fine. For example, I’m typing this on Brave mobile browser (latest version) and it also won’t let me bring up that menu.
I didn’t already have any other Chromium apps on my phone, so I downloaded Brave and, sure enough, the same bug is there. If the issue’s already been fixed upstream, then I hope Obsidian can update their dependencies or maybe even roll back if it’s necessary. Switching keyboards isn’t something most users need to do, but it’s essential for me, so for the time being I can’t use Obsidian any more.
If you go to the gboard settings, go to preferences, there should be a language switch key. Unfortunately it only cycles through them. Seems to be the only option. I also tried a month old version of gboard and still had issues. So not sure what’s going on.
Use the ‘:globe_with_meridians:’ next to the language Language space bar. It helps switch the language without bug.
Doesn’t seem to be an edit button, but with chrome, it’s the canary version that works. And turns out I was testing edge canary wrong, it doesn’t work. But the fact it still works somewhere now.
I have big news! The bug isn’t related to obsidian but with android system webview. Notice the following pattern:
  • Chrome with chromium v155 - broken
  • Chrome canary with chromium v158 - works
  • Brave with Chromium v155 - broken
  • Edge Canary with chromium v157 - broken
  • Obsidian with webview v154 - broken
  • Obsidian with webview v155 - broken
  • Obsidian with webview canary v158 - works
Switch to android system webview canary (make sure to open the app to switch) and it should work. Otherwise, wait until regular we view is updated to v158
This worked for me, thanks. Weirdly, I had to add WebView DevTools to my secure folder and open it from there in order to make the option selectable.
Android system webview beta has now got to v158. So you can switch from canary to beta at least.
I am facing this issue. I don’t have Android system webview installed from PlayStore.
This issue happens for over a month. Just noticed the keyboard switching happens with other apps (Notepad Free for example) and also it works well in Chrome browser itself.
Obsidian Version 1.15.0 (396)
One Ul Core version 5.1
Android version 13
Webview isn’t a public app, it doesn’t appear on the play store or regular app list. Go to settings, apps, all apps, then search for webview. Click on it, then scroll to the bottom, it should say something like “Version 156.0.8078.47”. If so, go to the play store, search for webview beta, install it, open it then set it as the default provider.
I have a similar issue with Samsung keyboard. When I go to the clipboard tool at the toolbar, select a clipvalue, then pressing the delete button should give me a confirmation popup message. It is shown, but immediately goes away and the keyboard as well. When I am in a different edit field (not Obsidian), for instance the app search bar in the apps screen, I succeed to delete. It is such a rare occasion, yet such a weird type of bug.
I found out it is an upstream bug in Webview, not in Obsidian. See specified issue in Chromium: Chromium
It also shows another workflow related issue: when the notifications area is pulled down, the keyboard is lost as well, leaving only a blinking cursor. An additional tap is needed to invoke the keyboard.
The Samsung keyboard language switch didn’t expose the bug, the sphere button does give a drop down box, but it does not collapse. With Gboard it does happen, workaround is to tap the sphere button instead of a long press, to switch between languages.
I’ve tested with app Chrome Canary 159.0.8154.0, site codemirror.net and in the first edit field and tested ok, no bug.
I tried to look up the roll out to stable Webview, but could not find definitive information. Haystack kind of something…
Anyway, 1 Google dev said his teammate is “swamped”. I can only imagine… Yet it also reminds me of the (supply) chain of software dependencies. In this case an earlier bugfix at their side can suddenly create a unexplainable bug at our Obsidian side. Something to remember next time. System app Webview updates 6 weekly automatically I’ve read somewhere. In the app Total Commander you can look up the date for the last update, that could give someone a clue if something has changed (after that date). It is probably the only variable, apart from updates of Obsidian (which I do manually, instead of automatic updates in Google Playstore). Well, next to OS, device launcher (eg OneUI from Samsung) and keyboard app updates. And perhaps more?
Android System WebView was recently updated to version 157.0.8103.40 and the issue is fixed now for me.
Did a manual update (Options > Developer options [to activate: tap the Build number option seven times under your phone’s settings in about phone [ > software information/data]] > WebView DevTools > tap the ellipsis (3 vertical dots) in the upper right corner > Check for WebView updates [select app store] > update WebView).
In app Total Commander it shows the 157 version:
Yes, deleting an item of the Samsung keyboard’s clipboard works, longpressing globe button on GBoard to switch languages works.
However, the keyboard itself still collapses.
So, you still need an extra tap to activate the keyboard.
I just noticed this difference in Chrome Canary 159 as well. When I add an appointment in Google calendar, the keyboard remains active/shown in screen and I can continue typing.
The collaps is also happening when you pull down the notifications area from the top.
Either it needs follow up in the Chromium issue or report a WebView bug from the ellipsis menu in WebView DevTools (see mentioned above).
Installed ‘Android System Webview Beta’ as mentioned above. Keyboard switching started working. Uninstalled the same, the keyboard switching still works well. Just for info.
