Bug: Double-click on highlight in PDF reader
Double-click on highlights in PDF reader results in the highlights disappear and later asking to save the PDF file.
Did you follow the troubleshooting guide? [Y/N] Y
Double-click on highlights in PDF reader should not temporary remove the highlights.
Double-click on highlights in PDF reader result in the highlights disappear and later asking to save the PDF file.
Obsidian version: v1.8.1
Installer version: v1.6.5
Operating system: Darwin Kernel Version 24.2.0: Fri Dec 6 18:41:43 PST 2024; root:xnu-11215.61.5~2/RELEASE_X86_64 24.2.0
Catalyst license: supporter
Insider build toggle: on
Base theme: light
Snippets enabled: 18
Additional Information
2025-01-12_14.57.58_CSX
Afterwards, I try to open different note and it may not focus on the current PDF tab, and other time it will ask to save the PDF file.
thanks
Will be fixed 1.8.3
