[X] iOS
[ ] Android
Obsidian Mobile version: v1.2.1
With Avenir font, there is weird behavior when I try to bring the cursor to the end of a line.
I’ve recorded a screen share to demonstrate.
It happened in the past when I had avenir font activated via CSS, and again now with Avenir activated in Obsidian custom font settings.
EDIT:
Unfortunately I clicked „solution“ before writing my comment, hence my comment here as edit:
Hi @anon12638239 , you‘re a genius! Actually Avenir Book didn‘t fix it, but I‘ve added Avenir Next instead, and with that it works just fine
For whoever might want to use this solution: There‘s no need to manually add any font in an Obsidian folder. Simply go to the font chooser in the Obsidian settings, and type Avenir Next. I needed to add a space after Next, in order to be able to add the font.
