Hello everyone I am a new user. I just downloaded the breadcrumbs. I couldnt manage to work. I looked at its wiki. I did not understand it
. Any good videos or explanations do you know? step by step ![]()
Yeah I got confused by it too. It sounds like you need some manual setup.
What will you be using it for? If you just want a simple breadcrumb that automatically shows the folder structure of your notes, try “Quick Explorer”. It also adds a basic breadcrumb feature, with no setup.
And then you can use that breadcrumb to navigate too.
ye explanation is not good enough. I will try yours. Thank you
