For every book I have a note generated with booksearch plugin. I have a YAML in which there is a link to a cover image. Every so and often booksearch can’t find a image for a particular book and neither I can with google image.
I created a bookshelf using many tips from Bucaneer
Having local images I use in field of my YAML
cover: [[coverbook.jpg]]
while for cover image
Now, if I use this query dataview I can view my cover image taken from web in the bookshelf:
TABLE WITHOUT ID file.link AS "Titolo", author as Author, ("") as Cover,
rating as Voto, Anno_di_lettura as "Anno letto", pages as "Pag."
From "002 Reading"
WHERE file != this.file
For cover image from web I have:
(“”) as Cover,
with another query dataview I can see local images:
TABLE WITHOUT ID file.link AS "Titolo", author as Author, embed(link(cover, "150")) as Cover,
From "002 Reading"
Where I use this code for visualizing local image:
embed(link(cover, “150”)) as Cover,
Last code came from this discussion Local image
(solution by mnvwvnm)
PROBLEM:
With first query I can’t see local image
And obviously I can’t see the first two images when I use the second query.
Is it possible to create a if-then clause for having both kind of images?
I tried several solution without success. I can’t create a query in which web cover and local image can be seen in one bookshelf
embed(if(contains(cover, “http”) || contains(cover, “https”), link(cover, “150”), “file:///Users/gabriele/Documents/Obsidian%20Vault/Attachment”)) AS “Cover”,
choice(contains(cover, “http”) || contains(cover, “https”), embed(link(cover, “150”)),
embed(if(contains(Cover, “http”) || contains(Cover, “https”), link(Cover, “150”), (“./” + Cover))) AS “Cover”,
