ZERO0
January 6, 2025, 7:56am
1
Blurred font,But clicking on the system taskbar won’t cause any problemsBlurred font,But clicking on the system taskbar won’t cause any problems
I have enabled safe mode and there are no third-party plugins
In the last picture, I clicked on the system taskbar and the font became clearer
I also experience this situation when using ALT+TAP
ZERO0
January 6, 2025, 7:57am
2
MD documents will not encounter this issue
ZERO0
January 6, 2025, 7:59am
3
Changing software properties still cannot be changed, and modifying graphics card driver settings still has no effect
ZERO0
January 6, 2025, 8:01am
4
This is using default theme and no other visual adjustments. Screenshot is with Consolas font and Live Preview mode, however this happens in source mode and reading mode as well.
RGB subpixel rendered text for increased text clarity.
Only grayscale antialiasing (see screenshot) for text. However, text in code blocks will have RGB subpixel antialiasing.
Operating system: Windows 10
Debug info:
Obsidian vers…
I found a similar problem
But my problem appeared on the whiteboard notes
ZERO0
January 6, 2025, 8:06am
6
If I place a link on the whiteboard notes, his webpage will also be blurry
But it will not be affected by clicking on the system taskbar
ZERO0
January 6, 2025, 10:51am
7
I don’t know why, but I changed the theme and this problem has been significantly alleviated
Elegance
This theme can cause severe font blurriness, and other themes can also cause this issue, but not as severe
ZERO0
January 6, 2025, 10:52am
8
The appearance of other themes has minimal impact
ariehen
January 6, 2025, 11:06am
10
Eight posts in and you still haven’t included the bug report template. Please do so.
ZERO0
January 6, 2025, 11:10am
11
The bug was caused by the theme skin, and I provided feedback to GITHUB
system
Closed
April 6, 2025, 11:10am
12
