I am using the Blue Topaz theme for Obsidian and it looks great. However, I want to change the font the default font, but I see no way to do that. I see the picture for the Blue Topaz theme suggests there is a Style Settings plugin, where can I access that?
Hmm, I see there is a generic Community Style Settings plugin.
Yes, the Community Style Settings plugin is used by quite a few themes to customize the settings. Blue Topaz is quite an overachiever in this area, there are a TON of things to customize. So definitely go ahead and install and activate that plugin.
Tip: you can open the style settings in a second window, so you can see the effects of your changes immediately. cmd+p, style settings: show style settings view. I forget where I learned that trick, but it’s made customizing things a LOT easier!
I dont see how to change the font though…
