Create a page with at least 2 bullets
Under some bullet create a nested code block.
like this -
On another page embed a block reference to the bullet with the code block
An anchor will be added AFTER the code block’s trailing backticks, breaking the code block.
The embed will instead embed the whole page.
Trying to link the block again will actually create a new broken anchor again.
Please add a screenshot of your note in edit mode.
Block link behavior breaks very easily.
I think the pattern is if you use any markdown other than a generic single-level bullet, it will break all block link behavior and treat the link as a note link. An example:
Vanilla and working as intended (only the block is embedded):
Add a single markdown-style block quote > and the link is treated as a link to the entire note instead of a link to the block:
Same as above, but scrolling the preview note to illustrate:
We no longer show the whole page in case of broken header/block links.
I gonna close this BR and point everybody to this FR.
