Block reference without space changing reference on link autocomplete
In note ‘Definition’ create a block with a reference, e.g.
- (Acronym: Definition)^def-acronym
In another note, reference the block with
![[Definitions#^def-acronym]]
When present with link autocomplete, select def-acronym from the Definitions page
Did you follow the troubleshooting guide? [N]
The block should be referenced, with the reference unchanged and display
  • (Acronym: Definition)
On selecting autocomplete, if there is no space between the block and the ^, a new unique id is created for the block and the original one is ignored and changed so that it is no longer a referenceable code.
I.e. selecting def-acronym from the auto complete menu resolves as
![[Definitions#^3a7566]]
Going to the Definitions page, this line has now become
  • (Acronym: Definition)^def-acronym ^3a7566
The ^def-acronym is no longer formatted as a reference but ^3a7566 is
If you include a space before the block reference then the id is not modified on selection and ^def-acronym is maintained correctly
Obsidian version: 1.12.7
Installer version: 1.11.7
Operating system: Windows 11 Enterprise 10.0.26200
Language: en-GB
Community theme: Minimal 8.1.5
Plugins installed: 8
Plugins enabled: 8
1: Dataview v0.5.68
2: Homepage v4.3.1
3: QuickAdd v2.12.0
4: Templater v2.18.1
5: Tasks v7.23.1
6: Paste image rename v1.6.1
7: Minimal Theme Settings v8.2.1
8: Style Settings v1.0.9
Either the reference should not appear valid in the link auto complete or should not be modified if selected in the autocomplete
Including a space is the way to name a block in Obsidian. From the documentation:
You can also create human-readable block identifiers by adding a blank space followed by a caret (^) and the identifier.
source: Internal Links - Obsidian Help
That your example looks like a block ID in Live Preview is a quirk. When you switch to Reading, you should see that the syntax without a space renders as regular text and not a block ID, in accordance with the docs.
The feature itself isn’t part of markdown, so there are no external specs for it, just the Obsidian flavor.
The suggester can bring up all blocks, even unnamed ones. Comparing, the version without a space doesn’t actually show up as a pre-named block ID in the suggester.
The one with the correct syntax (a space):
The one with incorrect syntax (no space):
For clarity, are you saying the behaviour is not a bug but a “quirk”? The app acts in an unexpected way, hence raising it
Without a space, it’s not a block ID.
Live Preview makes it look as if it were a block ID, but it is not. That false appearance is what I referred to as a “quirk” of Live Preview.
If Live Preview and Reading were to be made exactly equal, then per the docs, the false appearance in Live Preview is what ought to be fixed (making it clear that it’s not a block ID when there’s no space). Reading view has the correct rendering.
Either way, the functionality is correct as is. A space is required to make a block ID.
