Block Reference uses absolute path by default?
I tried to insert block reference in sandbox by:
  1. open a note in the sandbox
  2. type [[Get started with Obsidian]]
  3. then in [[Get started with Obsidian]], press ^, and select some text to create a block reference.
  4. then we have:
  • as I set the configuration to use short path if possible for all the links, I expect that the block reference using a link with short path, i.e. [[Get started with Obsidian#^26d6b9]]
  • however, using the method mentioned above, the block reference link is:
    [[Guides/Get started with Obsidian.md#^26d6b9]]
Moreover, now, if I change the location of Get started with Obsidian.md, eg. move this file to the “Formatting” folder and accept the auto update, the block reference link changes from
[[Guides/Get started with Obsidian.md#^26d6b9]] to [[Get started with Obsidian#^26d6b9]] automatically.
I think the link for block reference should follow the configuration in obsidian. But what I observed is a misalignment, even for the actions performed by Obsidian automatically.
Is this a bug?
Headers was fixed and blocks will be fixed in the next build (mentioned in Discord).
It’s a good news!
Thank you!
Thank goodness. This is quite a frustrating bug.
