Blank Screening on Startup
Launch Obsidian in any state.
As much as I could, considering I can’t see the app.
The app in it’s normal state, displaying menus, text, etc.
The screen goes blank and terminal spits out some magic errors I can’t decipher. Guessing it’s a rendering error, as the mouse still recognizes text. Extended log file given with the other attachments.
[4894:0716/122938.542824:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
[4894:0716/122938.543053:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
[4894:0716/122938.568591:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
MESA-INTEL: warning: Haswell Vulkan support is incomplete
[5021:0716/122938.912646:ERROR:shared_context_state.cc(81)] Skia shader compilation error
// Vertex SKSL
#extension GL_NV_shader_noperspective_interpolation: require
uniform float4 sk_RTAdjust;in float2 position;in half4 color;noperspective out half4 vcolor_S0;void main() {// Primitive Processor QuadPerEdgeAAGeometryProcessor
vcolor_S0 = color;sk_Position = position.xy01;}
// Fragment SKSL
noperspective in half4 vcolor_S0;void main() {// Stage 0, QuadPerEdgeAAGeometryProcessor
half4 outputColor_S0;outputColor_S0 = vcolor_S0;const half4 outputCoverage_S0 = half4(1);{ // Xfer Processor: Porter Duff
sk_FragColor = outputColor_S0 * outputCoverage_S0;}}
// Vertex GLSL
#version 300 es
#extension GL_NV_shader_noperspective_interpolation : require
precision mediump float;
precision mediump sampler2D;
uniform highp vec4 sk_RTAdjust;
in highp vec2 position;
in mediump vec4 color;
noperspective out mediump vec4 vcolor_S0;
void main() {
vcolor_S0 = color;
gl_Position = vec4(position, 0.0, 1.0);
gl_Position = vec4(gl_Position.xy * sk_RTAdjust.xz + gl_Position.ww * sk_RTAdjust.yw, 0.0, gl_Position.w);
// Fragment GLSL
#version 300 es
out mediump vec4 sk_FragColor;
noperspective in mediump vec4 vcolor_S0;
void main() {
mediump vec4 outputColor_S0;
sk_FragColor = outputColor_S0;
Errors:
link failed but did not provide an info log
Extended log file.
This is what it looks like on startup
After moving the vault to another location temporarily.
Perhaps it is implicit somewhere in the error, and I missed it. Or maybe the devs can already tell from the error. But could you give more information, like your OS, Obsidian version, etc? Have you ever run Obsidian successfully, or is this your first try?
Since there seems to be shader errors, perhaps you could also mention what graphics card you have.
OS: Artix Linux
Obsidian Version: 1.3.5
GPU: Intel 4th Gen Core Processor
I’ve been running Obsidian since July 1st and had no issues.
I’ve run the official AppImage instead of the Arch repo build that I’ve been using, and it seems to function just fine. Feel free to disregard the bug report if that disqualifies it or something. I will be looking into the repo build, but have no experience interacting with builds for closed source software.
I’ve seen other blank screening bug reports, but not sure if these errors are similar at all.
Link to Arch repo build if interested:
https://archlinux.org/packages/extra/x86_64/obsidian/
Direct link to PKGBUILD (note the interactions with electron at the end of file):
I am gonna archive this. Beyond using the arch package you have also a very old cpu/gpu. That might be an issue.
Please don’t. I’m having the same error just after running sudo dnf update, aparently obsidian wasn’t updated but some dependecies were. I’ve been using the flatpak for 2 years and have no clue why this is happening.
I have found a workaround for anyone using the flatpak:
sudo flatpak update org.freedesktop.Platform//22.08                  --commit=5644f61a158b5437141ba41ecba1e71ccf2d29caaaa24ae04251d2f7fcd9daeb
sudo flatpak update org.freedesktop.Platform.GL.default//22.08       --commit=60292a56526a549372343d417b6db843890d917882e1e64bee9fc4e7f187946f
sudo flatpak update org.freedesktop.Platform.GL.default//22.08-extra --commit=b280745e536d10781419e9f6f98e65d48839672270193feedc59d7df3f5c7dea
sudo flatpak update org.freedesktop.Platform.Locale//22.08           --commit=ceb68067dcf1f6a93ae0d920dae301ff752c4f27e1718273c97fc2017cf5c35f
I am also running into the same issue.
With new hardware:
CPU: 12th Gen Intel Core i9-12900HK
GPU: Intel Alder Lake-P
OS: Fedora Linux 38 (Workstation Edition) x86_64
Can confirm that the workaround above fixed it, thanks!
