The aesthetics of Vextab usually wont match well your theme, specially in dark mode.
So I made a CSS snippet that removes the background and also will invert the colors on dark mode.
.block-language-vextab, .block-language-quicktab{
background-color: transparent !important;
.theme-dark .block-language-vextab, .theme-dark .block-language-quicktab {
-webkit-filter: invert(100%);
Before:
After:
btw you can also remove the “vexflow.com” watermark with the following:
.block-language-vextab svg text[x="275"], .block-language-quicktab svg text[x="275"] {
display:none;
