Hello, in the gif I showed How I changed the settings menu width to make live test of plugin features on the Kanban card. But for other experiments, is it possible to move the floating settings menu for better testing or is there more convenient way than this? Thanks.
Style Settings can be opened in its own tab with the command Style Settings: show style settings view
. You can then Split right
view it in a different tab group.
For the main Settings (including Style Settings), you can open any note in a pop-out window (Open in new window
) → drag that off to the side → open Settings in that. That way you can adjust the settings while viewing your main window.
