Better indicator that audio recording is active — especially on mobile
The only way to tell that Obsidian’s core plugin Audio Recorder is actively recording audio is the colour of an icon on the ribbon.
This is particularly a problem on mobile, where the ribbon isn’t present. You have to invoke the record audio command and then cross your fingers that you did not misclick or make some other mistake when starting the recording.
There have been a few times where something did go wrong when trying to start the recording, and the recording never started, so I wasted precious minutes only to realize once finished that nothing was being recorded.
Once Audio Recorder’s Record Audio feature has been started, provide some other visual cue on the interface that recording is happening. It’d be great if this could be a waveform or some other visualization that provides visual feedback of what’s happening with the recording, but even just a classic “red light” indicator would be better than what we currently have.
On desktop this is rarely a problem.
On mobile: invoke the command/tap the command button on the mobile menu and cross my fingers.
I have the same problem.
I find the experience can also be made better in desktop too.
The place I would want to see the visual cue on if the recording is happening is the place in the note where that audio is going to be placed post recording.
So I small "wavy three dots " around that area would do the trick in my view.
I wouldn’t prefer to see the cue in ribbon as I wouldn’t want my ribbon to be cluttered.
To be frank, I dint realise the icon in ribbon is changing while the recording happens until I saw your post here @ryanjamurphy .
May be I’m too ignorant
