Best way to dictate a quick note into Obsidian via Siri
What are people doing in July 2025 ?
I tried some older shortcuts
but they weren’t reliable.
I also tried the “Hey Siri, can you make a note in Obsidian”
Here’s a step-by-step guide based on my setup for quickly recording a task or note and saving it to Obsidian using Quick Capture:
:purple_circle: Shortcut Name: Obsidian task
:wrench: Step-by-step Setup in the Shortcuts App:
1. Open the Obsidian App
  • Action: Open App
  • App: Obsidian
This ensures that Obsidian is launched when the shortcut is run.
2. Choose Input Method
  • Action: Choose from Menu
  • Menu Items:
    • Dictate
    • Write
This lets you choose whether to dictate or type the task manually.
3. If “Dictate” is chosen
  • Action: Dictate Text
  • Action: Set Variable
    • Variable Name: inputText
    • Value: Dictated Text
The dictated input is stored as a variable inputText.
4. If “Write” is chosen
  • Action: Ask for Input
    • Prompt: Tell me
    • Value: Ask for Input
This allows manual typing and saves it to inputText.
5. Create a Task Text Block
  • Action: Text
  • Content:
    - [ ] (@Current Date) inputText
The [ ] makes it a task in Obsidian, and it includes the current date and your input.
6. Quick Capture to Obsidian
  • Action: Quick Capture
  • Content: Text (from above)
  • Send to: ToDoS (your chosen Obsidian vault or note location)
This sends your task to the specified location in Obsidian.
7. Finish with a Clean Exit
  • Action: Wait
    • Duration: 5 seconds (optional but gives time for Quick Capture)
  • Action: Go to Home Screen
This ends the shortcut cleanly and returns you to the home screen.
:white_check_mark: Result:
You tap your shortcut → choose Dictate or Write → speak or type your task → it is timestamped and sent to Obsidian as a checkbox task.
I hope you get a sense of how to implement it on your end.
Cheers, Marko :nerd_face:
I dictate into Drafts or Notes, then later copy it over to Obsidian. (I could setup a nice automation in Drafts to template and transfer it, but I haven’t had the patience to learn how.)
