When you’re using a format like that to list your notes on that customer, then it’ll generate disconnected lists on each note related to each of the fields. Consider the following note:
[customer:: A], [hours:: 10]
Made a call to [customer:: B]
[customer:: C], [hours:: 12]
Customers: `= this.customer`
Hours: `= this.hours`
Total of hours: `= sum(this.hours) `
Which has this output:
Due to how these fields are connected to the note itself, and not interconnected, you’re not able to tell which hours belongs to which customer, nor which customer actually misses the hour field completely. These fields are example on using the note context for defining the field.
A better approach would be to use the list context to correlate the various fields:
- [customer:: A], [hours:: 10]
- Made a call to [customer:: B]
- [customer:: C], [hours:: 12]
- [customer:: A], [hours:: 5]
- [customer:: C], [hours:: 2]
### All hour related list items from current note
```dataview
TABLE WITHOUT ID item.customer, item.hours
FLATTEN file.lists as item
WHERE file = this.file
AND item.hours
### Summed up hour items, grouped by customer
```dataview
TABLE sum(rows.item.hours) as "Total hours"
AND item.hours
GROUP BY item.customer as Customer
This example holds two queries, one which just the dedicated items related to hour notes, and which then forgets about the call to “B” since it doesn’t have any hours
field related to it (the AND item.hours
part of the queries).
In the next query it groups these entries by the customer using GROUP BY item.customer
, and this moves all related fields into the rows
object. So what was item.hours
is now grouped into rows.item.hours
which can be used by the sum()
to calculate the sum of hours.
These example queries are limited to the current note using file = this.file
, so by removing that you’ll look at all of your notes. Note that it’s wise to limit the query to the smallest file set you’re able to, like doing FROM "Daily notes"
or similar to avoid scanning your entire vault.
