Best flashcard method in obsidian
which one is the best plugin to do flashcards and spaced repetition in obsidian?
I know there are some plugins that connect obsidian to anki, and plugins inside obsidian that does the spaced repetition without any other app.
I’m curious to know which one do you think is the best!
I’m going to start using flashcards right now, and I wanted to know your views about the options… Since there are so many, I wonder how people actually use it, if they switched from one workflow to another, etc.
What are your thoughts about it?
