Behavior of searching multi tags maybe it’s a bug?
What is the difference between adding and not adding ‘#’ symbols?
The reason is that when I find that searching for multiple, it will cause the tag to find the title
file:tag1 and tag2:
tags:
- tag1
- tag2
### tag1 tag2
file:only tag2:
tags:
- tag2
# tag1
## tag1
### tag1
When I expected to search only tags in metadata:
Then I found out that the official documents stated that
Find tag in file.
Example:tag:#work
Note: Sincetag:
ignores matches in code blocks and in non-Markdown content, it’s often faster and more accurate than a normal full-text search for#work
I tried add the ‘#’ sign, try to accurately match:
It’s too strange to understand
y
Multiple tag queries work well
This problem is also applicable in the search box
Accurately match multiple tags when searching
Is it normal to match the title? If it is not normal, you need to exclude
Obsidian version: v1.6.7
Installer version: v1.6.3
Operating system: Windows 10 Enterprise 10.0.22631
Please forgive my translated expression
