Batch Move Based on Tags
I want to batch move all notes with a particular tag wherever they exist in the vault to a particular folder in the vault. I’d prefer not to have to select each file individually or I could just use Move file to… I’m hoping to get it all done at once.
I installed the Auto Note Mover plugin, set up a rule and set it to manual. It says “You can trigger by command” but I have no idea what that means. What command? The command pallette has Auto Note Mover: Move the note but I want to move all notes with a particular tab.
I tried Auto mode and it moves the new file when I add the tag but does nothing I can tell for existing files with that tag.
I found one way to do it but it seems a little clunky. In Auto mode I used the tags view on the right and renamed the tag I’m interested in moving. Then I renamed that back to the original tag. All the files moved.
