Basic question: getSelection() not working
Hi, I’m new to programming (self-taught) and this is my first time making an Obsidian plugin
I’m working on a small plugin that will help me format/clean up text (e.g. you’ve copied a paragraph from a pdf and the line breaks are all messed up)
so far I’ve copied the sample plugin (works fine), edited the main.ts, and recompiled it, made a manifest.json, and successfully loaded it into Obsidian and made sure it’s active. The problem is that it doesn’t work.
error message is as follows:
Uncaught TypeError: import_obsidian.Editor.getselection is not a function
    at Object.editorCallback (main.ts:28:49)
    at e.mobileOnly.zt.isMobile.e.checkCallback (app.js:1:1988281)
    at oK (app.js:1:1987579)
    at t.onChooseItem (app.js:1:2590183)
    at t.onChooseSuggestion (app.js:1:1564140)
    at t.selectSuggestion (app.js:1:1563690)
    at e.useSelectedItem (app.js:1:1561971)
    at Object.func (app.js:1:1559370)
    at e.handleKey (app.js:1:757237)
    at e.onKeyEvent (app.js:1:758493)
editorCallback @ main.ts:28
e.mobileOnly.zt.isMobile.e.checkCallback @ app.js:1
oK @ app.js:1
t.onChooseItem @ app.js:1
t.onChooseSuggestion @ app.js:1
t.selectSuggestion @ app.js:1
e.useSelectedItem @ app.js:1
(anonymous) @ app.js:1
e.handleKey @ app.js:1
e.onKeyEvent @ app.js:1
and the code itself is as follows (with console.log() to try and see if it’s working or not. if you know about better debugging methods in obsidian i’m happy to hear them)
import { Editor, MarkdownEditView, Plugin } from "obsidian";
export default class CleanerPlugin extends Plugin {
  async onload() {
    // paragraph cleaner
	function paragraph_cleaner(s) { return s.replace(/(?<!\n)\n(?!\n)/gm, " "); }
	// subtitle paragraph cleaner. doesn't replace newlines that start with a hyphen since that's probably a different character talking
	function subtitle_paragraph_cleaner(s) { return s.replace(/\n(?!-)/gm, " "); }
	// srt subtitles cleaner
	// remove SRT data, and group paragraphs using subtitle paragraph cleaner
	function srt_cleaner(s) { return subtitle_paragraph_cleaner(s.replace(/\d+\n\d{2}:\d{2}:\d{2},\d{3} --> \d{2}:\d{2}:\d{2},\d{3}\n/gm, "")); }
    this.addCommand({
        name: "clean SRT subtitles",
        editorCallback: (editor: Editor, view: MarkdownView) => {
            const selection = editor.getSelection();
            console.log("selection: " +  selection);
            console.log("replacement: " + srt_cleaner(selection));
            Editor.replaceSelection(srt_cleaner(selection));
	this.addCommand({
        name: "clean paragraph (e.g. copied from a pdf)",
            console.log("replacement: " + paragraph_cleaner(selection));
            Editor.replaceSelection(paragraph_cleaner(selection));
I did try both of:
Editor.getSelection()
editor.getSelection
as well but neither worked
I am working on a plugin called remove-newlines which i also created to assist with cleaning up copy-pasted text from PDFs, and on mobile I run into the same error. I found your issue by pasting the exact bug I was getting into my search bar.
plugin:remove-newlines:44 Uncaught TypeError: this.removeNewlinesFromSelection is not a function
    at Object.editorCheckCallback (plugin:remove-newlines:44:18)
    at e.mobileOnly.ql.isMobile.e.checkCallback (app.js:1:2041033)
    at RK (app.js:1:2040381)
    at t.onChooseItem (app.js:1:2630332)
    at t.onChooseSuggestion (app.js:1:1584862)
    at t.selectSuggestion (app.js:1:1584412)
    at e.useSelectedItem (app.js:1:1582271)
    at e.onSuggestionClick (app.js:1:1582007)
    at HTMLDivElement.s (enhance.js:1:10720)
Of course, this is simply not true, it happens to be a function in my class that is called appropriately.
removeNewlinesFromSelection(editor: Editor) {
	let selection = editor.getSelection();
	selection = this.removeNewlines(selection);
	editor.replaceSelection(selection);
I’m trying to refactor in a way that might fix it.
