Bases: List Properties Containing Links Do Not Render Links
  1. Create a list property on a file.
  2. Add a link to the list property.
  3. Create a base.
  4. Create a property on that base that references the list property.
Yes, I created a completely empty vault and followed the above steps to reproduce using only two files and no change to the default plugins, no community plugins, and no themes.
I expect to see the links in the property rendered as links.
It renders the raw string, including square brackets.
Obsidian version: v1.9.0
Installer version: v1.8.9
Operating system: Windows 11 Pro Education 10.0.22631
Catalyst license: insider
Insider build toggle: on
No additional information.
I think you created a formula property (a derived property). You need to add the base property.
Formula properties aren’t parsed as Markdown.
Ah, you are correct, thank you! Would still be nice to be able to show links for formulas, but this solves my use case!
