Bases: Limit scope for bases to single/list of directory
Created a note, noticed that my .base file included it in items list.
Provide the ability to limit a .base file to only look withing a single directory, list of directories, or only files with a certain tag
Current workaround
Add a tag that defines the view scope, then filter only notes that contain that tag
It’s already possible. You need to use global filters for this.
Noticed that you can achieve this after posting using something like is shown in the attached picture (second formula), where in my case “Busbar Joggler (263730)” is the folder name that contains all items to be associated to the .base file. While this works as requested, I think this functionality should be promoted as I can see it being used quite often.
