Show only the notes with the “promulgation” property “empty”.
The notes with the “promulgation” property empty are displayed, but additionally, random notes that do not have the “promulgation” property are also shown.
Obsidian version: v1.9.10
Installer version: v1.9.10
Thank you for the quick response. I just noticed that the behavior of “is empty” is the same for the number property type; it shows not only notes but also files, which shouldn’t be displayed!
Now I tried to display all notes with the “promulgation” property using the advanced filter:
note["promulgation:"],
since with simple filtering it seems impossible and only shows notes with a non-empty promulgation property. I intuit that with the advanced filter, all notes with the property, whether empty or non-empty, should be displayed.
