Bases is not sorted correctly for checkbox property
Clicking column title on the base
Or
Adding sort ascending or descending condition
Y
the ascending and descending order should be different
false → true (ascending)
true → false (descending)
the sorting is identical
Obsidian version: v1.9.10
Installer version: v1.8.3
Operating system: Darwin Kernel Version 24.5.0: Tue Apr 22 19:54:25 PDT 2025; root:xnu-11417.121.6~2/RELEASE_ARM64_T6020 24.5.0
Catalyst license: none
Base theme: light
works for me
Obsidian_dOCafY9LDG
I had the same problem as OP. The issue is that the sorting only works as expected for checkbox properties which are explicitly marked true or false. Sorting does not apply to notes where the checkbox property is absent or empty.
Since the documentation describes empty checkbox properties as behaving as false, I expected them to be sorted as false.
There is in fact a third state “indeterminate”. We will update the docs soon.
