Bases: formula not working on fields with CJK characters?
Hi team,
I’m really excited to start testing the database plugin, it’s certainly a killer feature. While playing around with the formula function, I ran into an issue: it seems that properties with CJK names aren’t working as expected.
As shown in the screenshot below, I tested this in a sandbox vault using numeric properties named "one", "two", "一", and "二" (the latter two being “one” and “two” in Chinese). The summation formula works fine with one + two, but fails when I try to use "一 + 二".
If I forcefully insert 一 + 二 into the .base file, it throws an error like this:
It’d be really helpful to have more guidance or examples on writing formulas. Thanks again!
thank you. This is a known problem will be fixed 1.9.1
