Bases: first instance of adding a formula duplicates formula and views
  1. Create new note in sandbox
  2. Type a base code block:
```base
  1. Select Properties > + Add Property
  2. Enter any formula (file.path will do) then tap the arrow to go back
    (Upon creating the first formula, the column is not automatically shown, as it is at later times when this feature is working well.)
  3. Select the new formula from the list, then click away from the table
Y
Expecting a table with the new column, like:
An empty table:
Video: https://skydriftmedia.com/debug-543565 (temporary link)
The code shows that “formulas” appears in the right place but also repeated in the wrong place (after a first “views”). Also, “views” is repeated several times as if saving new views as I type the formula. (I don’t type that slowly).
Obsidian version: v1.9.1
Installer version: v1.8.10
Operating system: Windows 11 Pro for Workstations 10.0.26100
Catalyst license: insider
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
