Bases - filtering using properties
filter a table view using properties.
So, I have a base block that shows a table with property ‘quote’. The page containing the block has property ‘quoteMatch’. If quoteMatch is empty then the table should show all notes. If the property contains a string then the table should only show notes where the quote property contains the string in quoteMatch
    filters:
      and:
        - quote.contains( if ( this.quoteMatch.isEmpty(), " ", this.quoteMatch ) )
Using a space for quote.contains() if quoteMatch is empty. Which mostly works but is less than ideal because it doesn’t allow for properties with no spaces or empty properties.
Is there a better approach?
quote and quoteMatch are text properties? If so, then how about:
filters:
  or:
    - this.quoteMatch.isEmpty()
    - quote.contains(this.quoteMatch)
Perfect. Many thanks
