Hello everyone,
I think the title is self-explanatory. Basically I would find extremly helpful to be able to add filter on bases results. For example, select the notes that matches the filters of another base. That should allow us to create a base that collects the results of multiple bases (I know i could join all the conditions in a singla base, but i need to merge from may views)
