Bases code changes when dragging to resize columns
  1. Create a base in a note with ```base code with one empty line between
  2. Click outside the code box to render the base.
  3. Add filters and properties
  4. Drag columns to resize
  5. Click on a line outside the base
    The base no longer renders because the code for column sizing has been duplicated
Yes, I did this in a vault with no community plugins or CSS Snippets in the default theme.
A base that is rendered correctly.
The base does not render at all.
Obsidian version: v1.9.2
Installer version: v1.8.9
Operating system: Windows 11 Home 10.0.26100
Catalyst license: insider
Insider build toggle: on
What the code looks like after I have resized columns:
This is in a note where I have added two bases:
