Bases card view requests remote images twice, logging a CORS error for each
  1. Create a note with a property pointing at a remote image on a host that doesn’t send
    Access-Control-Allow-Origin — e.g. cover: https://assets.hardcover.app/edition/32462067/40a20ed0-0786-4425-b775-0af66472e853.jpg
  2. Create a base with a cards view using that property:
      - type: cards
        image: note.cover
  3. Open the view with the console open.
    The card displays the image; the console logs a CORS failure for it.
Yes
Either the image is fetched once in the mode that’s actually needed, or a failed CORS-mode request for an image that has already rendered isn’t surfaced as an error.
A Bases cards view whose image is a property holding a remote https:// URL logs a CORS error per image:
Access to image at ‘https://image.tmdb.org/t/p/w500/ww6hnnEnV6qM0LWkopDE7rMKAYr.jpg
from origin ‘app://obsidian.md’ has been blocked by CORS policy:
No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
Failed to load resource: net::ERR_FAILED
The images render correctly anyway. So the image appears to be requested twice — once
plainly (succeeds, displays) and once in CORS mode (fails, logs). Only the second is visible
as a problem, and it produces one error pair per card.
With a few hundred notes this fills the console and makes it unusable for anything else.
Obsidian version: 1.13.4
Installer version: 1.12.7
Operating system: Darwin Kernel Version 25.5.0: Mon Apr 27 20:41:06 PDT 2026; root:xnu-12377.121.6~2/RELEASE_ARM64_T6030 25.5.0
Snippets enabled: 4
Plugins installed: 12
Plugins enabled: 11
1: Templater v2.20.6
2: Dataview v0.5.68
3: Chord Sheets v1.8.0
4: Markdown Furigana v1.3.0
5: Media Vault v0.1.0
6: TaskNotes v4.11.1
7: Calendar v1.5.10
8: Hearth v1.17.0
9: Iconic v1.1.10
10: Habit Tracker 21 v2.4.1
11: Full Calendar Remastered v0.13.5
Obsidian 1.12.7 · macOS 26.5.1 · default theme
Two host behaviours, both checked with curl:
image.tmdb.org — returns access-control-allow-origin: *, but only when the request
carries an Origin header, and correctly sets Vary: Origin. Errors here look
cache-related: a copy fetched earlier without Origin has no ACAO stored.
assets.hardcover.app — returns no ACAO at all, with or without Origin. Any CORS-mode
request for these will always fail.
thanks
