Base Filter - Inconsistent Behavior
I’ve created a base view for everything “Created Today” that is not of “type” “DailyNote” or of type “Meeting” - so my filter clearly says that the Type should not be either DailyNote or Meeting.
However, in this view, I’m getting inconsistent behavior. Sometimes it works correctly. And other times, after I click around in the page a bit, the same view starts showing notes that DO have the type property as “Meeting”. I find this really strange since the filter is still in place, but the results change on their own.
moved to help for not following the BR report template.
if you need informal help about bases, you may be better of on discord insider channel right now.
