Base doesn't add property when filter "has property" is set but property is not displayed
  • Create a base
  • add a filter “file” “has property” and add any property
  • Hit the + New button to create a new file.
  • The resulting note has the message: “This note will be filtered out because it doesn’t meet your criteria”
Yes
A new file that has the required property.
Base generates a file that gets filtered out of itself.
Obsidian version: v1.10.3
Installer version: v1.9.12
Catalyst license: none
The usual way to add a property to new notes is to add it in the “Property” dropdown, but there are plenty of situations where you will want a file to have a property that doesn’t show up in the base view.
thanks
it’s actually any property that is not displayed.
Will be fixed 1.10.5. no etas.
