I don’t know what happened. All of a sudden, the backlink does not work properly.
  1. create a new vault.
  2. create a note named abc
  3. create a note named test
  4. see the GIF
the backlink panel should refresh automatically.
the backlink panel refuse to update the last item
  • Operating system: MacOS 10.15.7
  • Obsidian version: 0.9.3Oct-13-2020 01-11-50
Thanks—it looks like the issue occurs when the links to abc in the originating document are deleted, not when they’re added. Is that right?
Does waiting a couple of seconds helps?
I tried. But waiting does not help.
@ryanjamurphy
It is not 100% correct. I upload the following GIF to show that:
  • by adding a new backlink, the ‘ghost’ backlink item is replaced by the correct one.
Oct-13-2020 13-23-30
in this example:
Oct-13-2020 13-02-23
  • by closing and re-opening the backlink panel, the backlink list is shown up correctly.
Will be fixed in v0.9.5.
Great to hear that!
