With Note A selected, click on the “Note B” link in the Backlinks for Note A section. The first time you click this link, the proper text in Note B will be scrolled to and briefly highlighted, as expected.
However, if you go back to Note A and once again try clicking the “Note B” link in the Backlinks for Note A section, while Note B will open, the embedded section is not scrolled to nor highlighted. In fact, Note B just opens to the beginning of the note.
Each time a linked reference to an embedded link is clicked, the appropriate note should open, scroll to, and highlight the embed in question.
Only works for first Linked Mention click, not subsequent ones.
One additional piece of clarification. It seems that the bug only appears if you first navigate to Note A via the graph. In other words, here are the steps to reproduce (after you have Note A and Note B created, per above).
Open Note A
Click the “Note B” link in the Backlines for Note A section. The text in Note B will be properly scrolled to and selected.
Now select Note A within the Graph of Note B pane. This will obviously cause Note A to open.
Now click the “Note B” link in the Backlines for Note A section. The text in Note B WILL NOT be scrolled to nor selected.
So, it seems opening a note via the note graph puts the backlinks for that note into some strange state that when clicking them, we don’t get the proper scroll and highlight behavior.
