Automatically Suggest Links with Imported Note?
Hi,
I primarily use Obsidian to import annotation files from Zotero. After importing, I go through the new note file and add internal links to connect passages with other notes in Obsidian. It’s a cumbersome process, and I’m worried I may be missing some links.
Is there a way to have Obsidian automatically suggest links based on my existing library? For example, say I’m importing a series of Zotero annotations from an article on suicide. If I already have a “suicide” note created in my vault, I’d want something that—highlights? auto-links? flags in some way?—all instances of the word “suicide” in the new note.
Thanks in advance for your help!
Do you know the core Backlinks and Outgoing link tab panels?
It will show all unlinked mentions in the current document and you can create a link with one click.
Or do you look for something different?
Ah, thanks so much! I knew about this feature, but didn’t click on the “unlinked mentions” section. This is everything I was looking for. Much appreciated!
