Automatically paste clipboard contents into QuickAdd Macro text box
I’ve set up a QuickAdd Capture Macro to send my clipboard contents to. Here’s what the macro looks like:
Here’s the text box I get:
I’ve also set up a Keyboard Maestro Macro to automatically paste the clipboard contents into the box. Here’s what that looks like:
For some reason, The QuickAdd box doesn’t recognize the %SystemClipboard% token from Keyboard Maestro. It’ll paste/type other things just fine, but not that. Am I missing something? If not, is there an Obsidian template/formatting tag that’ll grab the clipboard contents?
If you use Templater plugin, you can use <% tp.system.clipboard() %>.
Good luck.
I actually just now figured that out, thanks! :grin:
