I want a child note to automatically inherit the same properties as its parent note, such as tags, aliases, and other metadata, as soon as I create it.
I can create a new note inside an existing note using brackets like [[NoteB]]. By clicking that link, I can create Note B.
When I insert a template into the child note (Note B), I want it to automatically pull in the properties (like tags, aliases, etc.) from its parent note (Note A) without needing manual duplication.
I want it to be applied in the properties section, not just inside the note content.
Currently, I’ve made this work using Dataview, but it only works when I explicitly specify the out-link in Note B. And it doesn’t apply in the properties
section, but just inside the note section.
Have you had any luck figuring this out? I’m currently in the process of trying to do pretty much the same thing, with the caveat of wanting a metabind button in my parent note to launch the creation of the child which would inherit many of the parents frontmatter properties.
