In the journalling section of my Daily note template, I want that every paragraph is marked with the time of the day. Is such possible without pressing a shortcut every time I enter some text?
Run this command Templates: Insert current time. You can bind this command in the settings. On mac you could use ⌘1 or ⌘T. Obviously you could use these shortcuts for many useful actions. If you want both date and time, then the configuration is slightly more complicated.
